1 - 2 of 2 Posts
1998 Forester S
Hello.
I have a 1998 Subaru Forester and I had some problems with the alternator. I replaced the alternator and with the battery dead I used some booster cables. After that car died complete; main fuse was burned (80 A) but when I replaced the fuse it burned the second one right away. One mechanic disconnected the airbag from one plug (left side, inside the post, under the plastic cover, down) and since then car working fine but I don’t have airbag. Maybe because alternator was overcharging (17 V) or because I used booster cables is look like I need another air bag ECU?
Where is it this airbag ECU?
Thank you.
01 Forester Ltd
I believe the air bag the mechanic disconected on the passenger side or was it the drivers side i forget, is the air bag module that may be defective.
1 - 2 of 2 Posts
