1 - 8 of 8 Posts
99 UK S-turbo
AIUI the 2004 WRX has the later droplink type and is incompatable with an SF5 (unless you want to replace the laterals!)
Simon
'98 Forester
Just remember the Turbo sway bars do not have humps for the exhaust, I have STI bars on my Forester and had to drop the stock manifold down a couple inches ( Longer exhaust studs and stacked 5 gaskets per side ... and no heat shields ) ...
Hmm nice solution. I was thinking that there might be leaks between gaskets and was looking for spacers instead but I might try this too.. I want a 25mm+ on the front :p
DAMN guess I shouldn't have sold my 25mm FSB!
1998 Cayenne GTS 6speed
I have the chance to pick up a 22mm Whiteline rear swaybar for a 2004 WRX. I was wondering if this is compatible with my 2001 Forester L?
The simple answer is that it will not fit. You need bugeye (pre-2004) rear sway bar.
1 - 8 of 8 Posts
