1 - 2 of 2 Posts
2001 Forester S auto
I have a bad ground connection on my ABS module, and it was causing some erratic functioning from the braking system when driving. ( I temporarily disconnected the ABS relay or fuse (I can't remember which)). Now the problem has disappeared for three months. Can anyone point out where the ABS module is grounded so I can fix the connection? Thanks guys.
· Administrator
If you're certain the ground is bad, seems to me the simple solution is to run a new ground lead? :confused:
Looking on the wiring diagram ground distribution (snippet) below, you can see there are multiple ground connections & that the ground connection is shared.
1 - 2 of 2 Posts
