Hi All,
Like it says my Abs and Traction control lights are on. The vehicle doesn’t really drive any different except Abs and traction control don’t activate no pulsing and the *** end will swing out under power in slippery conditions. No other lights are on like the cruise control however I haven’t tried but suspect it doesn’t work. I have taken the rear sensors out and cleaned them up not that they were dirty. All fuses are good, I have unplugged the battery and ABS module, Brake lights work ( so I don’t think the brake switch),fluid is good. Is there a way to reset the lights or do they reset once the issue is resolve?
Any thoughts ideas or suggestions would be greatly appreciated.
Thanks!
Thanks!
