I have a 99 Forester, with about 350k on it
been a great vehicle
at highway speeds the car has excessive body roll when changing lanes or banking a turn. its uncomfortable
I would like to correct it. but im not sure what would cure it
I Replaced all 4 shocks last fall..but not the springs
If I replaced the Springs would that help?, could i use stiffer springs then stock?
also what about replacing the sway bar with a new stock one? would that help?
any other suggestions to get a stiffer ride?
99 UK S-turbo
I'd suggest you start with a stiffer rear sway bar, that will stiffen the car, also the rear subframe lock bolts seem to (to me anyway) make the car FEEL like its rolling less, as they make the rear more precise and less 'detached'. I wouldn't bother with new springs unless they are stiffer.
Simon
02 Forester L (sold) Manual
Rear sway bar, slightly larger, off a WRX, Outback, etc. Do a little reading on here to find which would work best for you. The stock bars are pretty wimpy. I doubt replacing it with a 'new' one will solve your problem.
If you don't need the gound clearance, lowering via WRX or similar springs will get rid of a lot of the body roll because you're lowering the center of gravity. But, you need matching struts to do that properly, and you just replaced yours.
none none
Has the handling gotten worse? Its possible that an endlink has failed (ie the ball has popped out) so that the swaybar is effectively disconnected. Do you get any clunking?
What shocks were installed?
2003 XS
A stock Forester shouldn't have "uncomfortable" body roll, although it's hard to quantify that. Given your mileage, it sounds like something is seriously worn or broken. Have the springs ever been replaced? Bushings? I'd make sure you have your bases covered before you go upgrading swaybars, lowering, etc.
BTW, lowineg the ride height of a Forester is like raising the ride height of a Porshe. It totally defeats the purpose of owning the vehicle in the first place. I know some people will disagree with that but that's my opinion.
