98 Forester L
Hey Guys, question. I just changed my trans filter and I had a brain fart and put the trans fluid in the othe tube.This is the front of the trans. Question: is this the front diff tube and if so will this do an harm....
2004 Forester 4EAT
yes and yes.
Make sure you fill the trans up correctly now. Then you will need to get a t70 torx to drain the front diff. You will want to "flush" the front dif by filling and then draining with gear oil a few times, and then fill to correct level.
1998 Forester
yes and yes.
+1 the diff drain plug will be a 21mm unless the transmission has be replaced with a factory reman in the last few years.
