Hello everyone. I am a new Subaru owner. I purchased a used 2007 Subaru with 93,000 miles. After buying I keep hearing all the head gasket horror stories. I am getting ready to have the timing belt and water pump done should I just get the head gaskets replaced now. The mechanic is going to do the timing included in price of heads if I get them done same time. I am just scared to get timing done now and a few months later the head gaskets need done. Thank you all so much.
@Jlivingston083 I see this is your first forum post, so welcome to the forum from Oregon! :biggrin:
If doing the head gaskets, with the timing belt maintenance, fits in your budget, go for it! :wink:
Keep in mind, if the head gaskets are not done properly, they can fail again. Same with the timing belt maintenance, if all the wear parts are not replaced, the timing belt could fail causing serious engine damage... a VERY expensive repair! :icon_eek:
Also...
'17 Impreza Hatchback CVT
+1, have it done properly and you should be in great shape. Most folks will say that a proper HG job will require pulling the engine.
2019 Crosstrek 2018 XT
Agree with the above. The guy better have done a ton of subaru in the past
