1 - 17 of 17 Posts
2010 2.5X Premium
Was just reading the manual for my 2010 Forester 2.5X and it says max weight for combined people and cargo is only 900lbs? That doesn't seem right, the average weight of 5 adults would have to be 180lbs or less if you wanted to put some cargo on the back. A family of four with grown-up teenagers could easily surpass the weight limited especially if mom and dad are a bit overweight plus you have the cargo. So really I'm assuming a few people here have surpassed the weight limit, ya know ski trip lots of gear and luggage plus 4 or 5 people that 900lbs is long gone. Assuming 900lbs is Subaru covering their butt number, what is the actual capacity...anyone know? What is the most weight you've had in your Forester before it bottomed out?
Smooshed FOTY 2011
Don't read too much into the rating numbers. They're primarily there due to the legal department. I'm sure it could safely hold a lot more, but 900 lbs. is what Subaru is tested to be a "consistently safe" load rating.
For example, some Common-Sense-Lacking people load their car up to the brim with stuff and people (say 1700 lbs.), roll their car and tries to sue Subaru because "no one told them it was unsafe to have that much weight in the car". THAT is why there are ratings on just about everything these days, not just as a scapegoat, but for people who just lack common sense. (You know, the type of people who sue because they burned themselves using a gas BBQ grille......Also the reason why there's a "WARNING: Flame is Hot" sticker plastered all over said grille.) :biggrin:
2017 Foz 2.5i CVT
I've spent some time on the Ford Truck forums and there are people who are surprised that a new Crew Cab F150 pickup, roughly the size of the Titanic, can have a total load capacity under 1000 lbs with the fancy trim package and options. This would include trailer tongue weight, etc. Perfect design for people who want to *wear* a huge truck. Completely stupid for someone who buys a truck to use... I believe that these trucks are also rated to tow a trailer that weighs 9000 lbs or something. So 10% tongue weight and you're done... You don't even have the capacity for a driver... A LOT of F150 buyers were pretty surprised at how wimpy their trucks really are (or how conservative Ford's legal department is).
Here's the GVW sticker on one of the giant F150's that comes in at a net payload of...900 lbs. This is a huge truck with a wheelbase of 157" and room for 5 or 6 huge guys. Plus a 6.5' bed you can fill with gravel.
http://i493.photobucket.com/albums/rr293/BazzerBreakfast/P2220124.jpg
And then there are the guys who brag about carrying 3000 lbs of dirt in the bed of that same truck. People have been overloading vehicles since they invented vehicles.
I'm sure that a few more lbs won't kill the Subaru, but if you break it or have an accident while overloaded, it's obviously your responsibility. Keep the weight low and centered in the vehicle for best results.
George
2015 Highlander AWD XLE 6AT
Manufacturers’ numbers games are always both fun and frustrating, IMHO, and Subaru doesn’t disappoint.
The vehicle ID plate at the bottom of my car’s driver-side “B” pillar states the Gross Vehicle Weight Rating (GVWR) is 4,480 lbs (2035 KG). Subaru’s spec sheet for the ’09 Forester says the various models’ curb weights range from 3,250 lbs for the base X model with an MT up to 3,460 lbs for the XT Limited w/ AT – a 210 lb. difference.
These numbers would suggest a load (options, passengers, and cargo) capacity ranging from 4,480 lbs – 3,250 lbs = 1,230 lbs for the Base X, to 4,480 lbs – 3,460 lbs = 1,020 lbs for the XT Limited.
I have no idea where the 900 lb (408 KG) capacity limit came from. Perhaps Subaru chose a value based on the heaviest model (the XT Limited w/ AT; 1,020 lbs) and then calculated in 10% safety factor (1,020 lbs x 90% = 918 lbs). Note that this is purely speculation on my part.
To further complicate matters, Consumer Reports lists their measured curb weights at 3,200 lbs and 3,405 lbs respectively.
HTH,
Jim / crewzer
2017 Foz 2.5i CVT
HTH,
Jim / crewzer
I'm guessing that vehicle mfrs can use 2 approaches to the GVW plate. First would be to do as Subaru does, and allow for the heaviest model with a whole bunch of add-on options in coming up with the payload. And use the same plate on every vehicle of that model they build. That is certainly easier and cheaper.
Now Ford, with the F-150, had guys seeing their model truck in a catalog or online and seeing 1500 lbs payload. Then they bought the truck with the fancy-donkey trim options or 20" wheels and looked at their sticker, only to note that their particular truck showed 900 lbs. These plates varied, but there were a lot of guys in the 900-1100 lb area and being really, really disappointed. There were also guys that assumed they were good for 1500 lbs as per the catalog listings until this thread had them look at their own plate. So Ford seems to have a bunch of different plates and use different ones for different trim lines and cab sizes--and even wheel size. The 20" wheels warrant a reduction in payload; this may be due to wheel weight capacity or leaving a bigger margin for low profile tires (which don't belong on a pickup truck in the first place).
Again, I don't mean this to be thread drift away from the Foz, but if it has the same payload as a 157" wheelbase Ford F150, seems totally reasonable to me :)
George
2009 Forester X 4 A/T
The Forester is a real hauler (based solely on the factory load 'limit') compared to my Honda Element which Honda has rated at only 675lbs of total load. really! kind of SUV can REALLY only haul 675lbs?
We all know it is legal dept B.S. to keep the idiots who would haul a load of friggin' bricks weighing 2,000lbs in their car from suing when they wreck- but still it is annoying to know that four high school football players are more weight than your new 'SUV' can supposedly handle.
Hey- how bout a Pontiac Solstice- 325lb total load limit there!
My assessment is that issue is not limited to Ford, as GM, Dodge, Toyota, and others are just as deeply buried in the locker-room style competition for the biggest numbers. :icon_wink:
As a former F-150 owner and a current F-250 Super Duty (crew cab, short bed, 2WD, XLT trim, 5.4L V8, 4R100 AT, 4.10 axle ratio, 8,800 lb GWVR, 15,000 lb GCWR) owner, been there, done that. However, I did select a heavy-duty option when I ordered my F-150, and various payload specs and packages are still available today. Unfortunately, the "Heavy-Duty Payload Package" and "Max Trailer Tow Package" options are generally described as "select availability" by trim level and certain chassis-, wheelbase-, and/or drivetrain configurations:
Heavy-Duty Payload Package — Increases GVWR to 8200 lbs. for
improved payload and towing; 17" 7-lug steel wheels; LT245/75R17E
all-terrain BSW tires; heavy-duty shock absorbers and frame;
upgraded springs and radiator; auxiliary transmission oil cooler; rear
axle with 9.75" gear set and 3.73 limited-slip gear ratio (Regular Cab
and SuperCab with 5.4L V8 only; req. Max. Trailer Tow Package)
Max. Trailer Tow Package (req. for towing over 5000 lbs.) —
Includes Class IV trailer hitch receiver; 7-pin wiring harness; upgraded
radiator; auxiliary transmission oil cooler; Trailer Brake Controller;
upgraded rear bumper; upgraded rear springs; heavy-duty front
eye bushing; and trailer tow mirrors (XL Regular Cab and SuperCab;
restrictions apply — see dealer for details)
But, yeah, if you want a gussied-up Lariat (see page 7), you can't get the Heavy-Duty Payload Package option.
Regards,
Jim / crewzer
2009 Forester XT Limited
I wonder how much of their "safety recommendations" have to do with overheating of the tranny or engine due to steep inclines or are in essence, mountainous terrain precautions rather than level land towing and weight restrictions?
2005 Forester X
Last weekend I easily had over 1000 pounds in the car - 5 adults plus a trunk packed with gear. Fully loaded, I drove across Colorado on I-70 to Utah, and the temperature gauge didn't budge. In Utah, we had to go offroad with 6 adults + gear in the Foz, and I only heard the tailpipe drag a couple times going over some deep, wide ruts. Don't be afraid to push the weight limit, but realize handling and power may suffer a bit.
The loaded trunk:
none none
A lot of it also has to due with the load rating of the tires and the weight limit for passenger vehicles.
Also the forester is absolutely not designed to be fully packed with 5 people and a full cargo area regularly. Its designed for 2 people + cargo or about 4 adults. Anymore than that and you really feel the difference in handling, mileage, strain on the transmission etc. You can do it on occasion but its not designed to be a daily heavy duty work horse.
The important ratings are the GFAWR, GRAWR (Axle weight ratings) and GVWR. These are the legal numbers. Go over these and you have the potential to run into legal problems in the worst case.
The 900 lb cargo carrying capacity, on the other hand, is a "safe" number if you don't want to go through the calculations, or don't understand how to calculate it. It has no legal bearing, however.
Let me give you an example: my '09X Premium MT
I went to a closed weigh station to get my unloaded weight (Oregon leaves their scales on when they're closed so the interested public has access to a free scale. It only has a 50 lb precision, though).
Ratings:
GFAWR: 2310
GRAWR: 2410
GVWR: 4480
"Cargo carrying capacity": 925 lb, I think (I'm not sure about this one. I am about the others.)
Unloaded vehicle weight:
F: 1750 lb
R: 1500 lb
Total 3250 lb
Let's say the driver is 150 lb, which probably adds about 90 lb to the front axle and 60 lb to the rear axle, putting it at:
F: 1840 lb
R: 1560 lb
Total 3400 lb
If I now load up the rear, centering the load over the axle, up to the GVWR, I've put another 1080 lbs in (1230 total including driver). But since this is all over the rear axle, I now have 2640 on the rear axle which is overweight by 130 lbs.
If instead you only load up to the "cargo carrying capacity", you add another 775 lbs (in addition to the driver) on the rear axle, for a total of 2335, which is under the rating.
So, by following the "cargo carrying capacity", you are more-or-less guaranteed to be within all ratings without worrying about the math. That's what it's there for. But if your load is well distributed, then the amount you can load it and stay within the legal ratings is probably quite a bit higher than that.
I hope this was helpful and not too technical. Sometimes it helps to see the numbers and an example behind a concept.
Nice write up, Math Guy; thx!
Sometimes yes, sometime no.
For example, the load rating on the OEM tires for my pickup truck is 3,042 lbs each. The rear GAWR is 6,084 lbs, the same as the capacity of two single tires.
The math for, say, an '09 Forester is different. The maximum load rating for the base X stock 215/65R16 96H tire is 1,565 lbs (ref ETRTO 36 psi spec), or 3,130 lbs for two tires. This is substantially higher than the front- and rear GAWR specs (2,310 lbs and 2,410 lbs respectively).
Even at Subaru's recommended rear tire pressure of 29 psi, these load index 96 tires are load rated at 1,312 lbs each, or 2,624 lbs for the pair, which is still higher than than the 2,410 lb rear GAWR.
HTH,
Jim / crewzer
2010 Forester XT
I guess I'm one of the jackasses. For one summer I towed my 2100 lb jet ski rig, with at least another 1000 lbs cargo in camping supplies and people, all around Colorado, in my 1987 Subaru Gl Wagon, with its 87 horsepower of glory. I even snuck it over Independence Pass at 12,000 feet (and virtually every other pass in the state) loaded down in that condition.
I wouldn't call it dangerous, as there is nothing I saw in doing this that is INHERENTLY unsafe, but I also know that A: I beat the hell out of that car in doing that, and B: You had to be aware EVERY SECOND that the car handles completely differently, and not giving yourself the room to stop, not managing your brakes so that you have brakes at a temp that they WILL stop, and doing everything else can lead to big problems.
Suffice it to say, I'm not terribly concerned about exceeding the payload limits, but you need to be aware that the car will take additional wear when you do so, and you have more of the safety burden on your shoulders as the car will NOT be capable of avoiding as many accidents- you must keep yourself from getting into those types of situations in the first place.
Ah yes, nothing like a white knuckle ride through the mountains with a long heavy trailer, been there done that, lol.
2009 Forester
Ratings:
GFAWR: 2310
GRAWR: 2410
GVWR: 4480
F: 1750 lb
R: 1500 lb
Total 3250 lb
F: 1840 lb
R: 1560 lb
Total 3400 lb
Thanks for this comment. I've got a 2009 Forester XT. It's about to be loaded with 820 pounds, including driver and luggage. 325 pounds of that is on a platform seated in a 2" receiver hitch. The rest is evenly distributed in the luggage compartment, except for 225 pounds in the front (me and some misc. crap on the pass seat). The platform extends a max of 28" from the front of the receiver, and most of the weight on the platform is 14 inches max from the front of the receiver.
How much trouble am I in?
Hi Ekh,
Sorry, I've been on vacation for two weeks, so only now see this post.
If the XT and X are alike, you may be right at the rear axle weight. (I figure ~100 lbs from the front seat load, ~325 lb for the cargo area load (-~50 lbs from the front), and ~525 lb for the platform load (-~200 lbs from the front). Add that to the 1500 lb when empty and you're at 2450 which is 40 lbs over the GRAWR. You might also find yourself tilted up more than you'd like too, since the front of the car is going to raise up a bit from the rear load.
If you do load it up like this, I (and others, probably) would be interested in your experience. A cargo rack may handle differently than a trailer, I reckon.
2008 Forester 2.5X Prem. 5spd MT
I thought I might chime in on this thread b/c I've been doing regular ~1/2 ton trips with my Subaru (last one today) hauling some compressed sawdust firewood stuff I've been buying for the winter... I bought 2 skids of the stuff from a local dealer and it's taken 5 trips or so to receive it all. Each trip I load as much as I can in the back seat, I put a few in the front floor and the rest go in the cargo area. Roughly ~384lb in the back seat, ~600lb in the cargo.
It definitely loads down the back end (adding stuff to the back seat really helps a lot) and handles different, but for the most part the concern is braking and cornering. Cornering's not bad as long as you don't exceed the speed limit (speed limits around here seem reasonable for a loaded-down vehicle) but braking requires advance notice unless you wanna slam it all the time...
You'll notice a little back & forth "bounce-sway" if the rear end is loaded up really well. I had all the load in the cargo area the first load, noticed a lot of that bounce-sway, subsequent trips I put more in the back seat and it wasn't as bad.
Last year when I first tried these blocks I took delivery of 66pkgs of them, that's about 1500lbs, that definitely did look like it was "overloaded"--the back tires were squished down noticeably and I forgot to pump them up so they were probably rolling at 32psi. The car felt like it bounce-swayed left & right a lot even going the speed limit. I spent most of the time going ~5mph below the limit. Wouldn't recommend trying that.
Also the total trip length with the load is about 27 miles, just coming home from work. 2008 Forester 2.5X Premium 5MT. The one thing that does perform perfectly with this kind of load is the engine. Can definitely get her going up a hill from a dead stop without much drama.
1 - 17 of 17 Posts
