Hi all.
I have a 2006 and bought some 7443 of Ebay to replace parking/brake lamp. Just after installation I saw a smoke coming from the LED's and removed them right away. It was actually the resistor that burned. After investigating I found there are different wiring on 7443, some are called 7443 CK Scionlife.com - View Single Post - Are your 7443 tail light bulbs causing you to blow fuses? You need CK-type bulbs!! and the ordinary is like this one: '97+ stop light in the rear is 7743 or 7740 bulb? - Club Lexus Forums (scroll a bit down) I'm just thinking which wiring is common in the Subaru ?
