1 - 8 of 8 Posts
Found this ....
Also contrary to popular belief , the antirattle clips and shims are available to order individually
Caliper Pins (6) is £19.08 + vat for 4
Sping Clips (4) are £7.62 + vat for 2
Shim (12) is £14.20 + vat for 4
Shim (11) is £14.20 + vat for 4
Hope this is of some use ...
Steve
2004 Forester XT
Thanks Steve, that has helped me out after finally finding this thread!!
I have one caliper leaking on the seam between the two caliper halves - this diagram doesn't show an internal seal so I must presume the two halves are just a metal-to-metal seal :icon_confused:
I don't suppose you stumbled across any other 4-pot exploded parts lists?
Cheers!
:biggrin:
thanks Peaty, found that link myself but no - it doesn't tell me if there is an internal seal for the fluid channel between the two halves of the caliper "sandwich"
Cheers
:biggrin:
There is no seal, I split one of the calipers not long ago for a refurb. I'd have split the other one too, but the caliper pins are seized and need a good kicking.
2004 Forester XT
I split this one and found it had been scored by the jaws of a vice :icon_evil:
Interestingly there *appears* to be a seat for an O-ring, but nothing was there.. They must be very fine tolerances on the sealing faces of each half of the caliper
Thanks Steve :biggrin:
Cheers!
1 - 8 of 8 Posts
