G
Guest
·Does this sound like a good idea? Struts have 10k on them and springs have 300 miles.
$300 a good price?
$300 a good price?
I have wagon Swift (higher spring rates than wagon soft "pinks") springs on sedan GR2s and I couldn't be happier with the setup. You can't go wrong either way with the KYB GR2s or adjustable KYB AGXs. I concur what others have said here. Get what you want. I am on my third setup already and pretty much had it with suspension work.FXT said:These have to be shipped from the west coast, so shipping is pretty bad. I cant find anything else. I will likely put wrx wagon pinks on the struts.
Should i skip the wrx struts and just get some kyb GR-2 struts or somthing?
I thought about doing springs only, but i dont know if the handeling will be up to snuff without better struts.
He wants too much for them or I would have been all over it.tre36 said:FXT, I spoke too soon. The guy selling the '05 struts and bits with progress springs is willing to separate the set. I believe this was the link in your other thread.
He is local but I have never met the guy. Another local member I know said he is cool.
http://forums.nasioc.com/forums/showthread.php?t=934994
You should jump on this and get the struts, strut mounts, bump stops, etc.
Can some confirm this? And assuming the above is true, the year takeoffs I want are 2004, correct? Any camber issues with the STI takeoffs?RussTTU said:The 2005-2006 sti suspension will not fit on the forester correct?
