1 - 20 of 35 Posts
admin
I snapped a few. Sorry, but my wife's Forester was parked right next to mine so I had to use a wide angle 10-20 lens to get the whole car in the shot. But you get the idea.
I hope your 235/50-17's are smaller than these Michelins. It was a little work to get them to not rub. I rolled front and rear fenders. Also I'm running 1/4 spacers in the rear.
2007 Forester XT 4EAT-VTD
Thanks! What width/offset are the wheels?
I was running P225/55-17 Advan S4s on the OEM 17 X 7 wheels with plenty of room to the strut in the rear - it looks like I have a little better than 1/4" clearance from the sidewall to the strut.
The section width of the P225/55-17 Advan S4s is 9.1" on a 7" wheel so I should be able fit up to a 9.6" section width.
The section width of the Bridgestone P235/50-17 RE960AS is 9.5" on a 7.5" wheel. These tires will be going on 17 X 7.5 Rotas.
I guess I'll find out soon enough if my calculations are correct!
admin
My wheels are 7.5" / 50 mm. I'm running 3 mm spacers in the front for clearance with GR-2 struts. The section width for these Michelins on 7.5" rim is 9.6" and they are tall at 26.6". I measured them and I got 247 mm for width and I suspect they may be even taller than the official spec say too.
2005 Forester XT
I'm on Forester GR2s and Whiteline Control springs, but I think it's about the same drop (or close to it) as the Swifts.
235/50/17 Yokohama S.4 on 17x8 +48 offset Rota Torques. I have 5mm spacers in the rear (probably could have gotten by with 3mm, but it would have been close).
02 Foz 4eat
Not what I want to read. I have a set of 235/50 Blizzaks waiting to go on. Just have to decide if they are going to go on BBS's (17x7.5 et53) or RS-Zero's (17x7.5 et 48). Looks like I may have to go with the Zero's.
02 Foz 4eat
Yep, the SF. Already have some minor plans for the car, brakes, suspension, exhaust and intake and wheels tires. Some of the stuff I have left from the FSTi will work on the SF (FSTi suspension, wheels/tires). Have an intake for it already, working on exhaust.
2005 Legacy GT
It's the SF.
Ah, right. Forgot you had the SF as well.
Discussion Starter #11
Your car looks great! I am actually looking at going with the Advan S4s again in P235/50-17, but I think I'll be OK with the 17 X 7.5 Tarmac 2s. Here's why...
After some exhaustive research on this site - especially in the Tire size / Wheel size / Offset /etc...log (will it fit?) thread, I have come to the following conclusions:
1. On a wheel with an ET48, a 9.6 inch tire cross section just clears the rear strut with no room to spare at the typical - 1.2 to -1.5 camber we usually end up with.
2. According to Tirerack, the P235/50-17 Advan S4 has a cross section of 9.5 inches on a 7.5 inch wide wheel.
3. On the Michelin site, they state that every .5 inch change in wheel width from the "measured wheel width" spec results in a .2" change in cross section.
4. In your case, the use of the 17 X 8 wheel added .2" to the cross section, resulting in a final cross section of 9.7 inches for that tire. I would have guessed that combo would not clear.
In my case, I'm sticking with the 7.5 inch wheel so according to my highly scientific research and analysis ( :icon_rolleyes: ), I should be good to go without spacers.
I guess I'll find out in a few weeks.
2005 Forester XT
Thanks for the compliment!
I remember looking at the spreadsheet in that thread before I bought the tires and saw a few others running 235/50/17 with no spacers and no rubbing. Based on that I thought I would be OK, I didn't think about how the extra half inch of rim width would come into play. Truth be told I would have just as soon gone with a 7.5 inch rim, but I was able to pick these up here on the board for a steal.
2005 Sequoia, V70R auto
I was running swifts with yoko s-drives 235/50/17 mounted to tarmac IIs. I had to run a 3mm spacer in the rear. I was able to run 215/60/17 with only minor rubbing in the fender in the rear.
Discussion Starter #14
Sounds right. The Yoko S-Drive in that size is listed as a 9.7" cross section on a 7.5" wheel. I'd like to go with the Pilot Sport A/S in that size but that too is listed as 9.7 inches on a 7.5.
In P235/50-17, the 960 A/S Bridgestone and Advan S4 are both listed as having a 9.5" cross section on a 7.5" wheel.
02 Foz 4eat
Based on your math above, the 9.5 section width of the LM-22 on the 7.5" wide wheel SHOULD fit. Still think I'll run the et48 wheels over the et53 wheels, just to be safe.
Discussion Starter #16
I think you will need the ET48 to avoid spacers.
My Advan S4s in P235/50-17 and Tarmac 2s are on the way. I will post my results here.
2004 FSTI automatic
Keep in mind the sub-zeros dont clear brembos...dunno if that is your plan tho.
My T2's are fairly close in the rear w/ re-01r 225x45, but I think there will be room for a 235.
2008 Forester AE
Looking at the 235/50 combo on Rotas;
would the 17x7.5 ET45 give the space needed to run S.Drive/PilotAS/Proxes4?
I am considering the SDR/Torque/T2s and they are all listed with this offset as well as the ET48..
1 - 20 of 35 Posts
