Hi has anyone successfully put a 225 65 17 Toyo open country at 2 or any tire that size on a 2009-2013 Forester? I was considering adding 1/8 inch wheel spacers in order to clear strut perch on front tires. Not sure if that will give me enough clearance. Strut perch is number 1 concern obviously. As far as rubbing the inner wheel well I am prepared to cut/ heat plastic etc. I have a 1 inch lift on vehicle. If not possible I guess I can go with Coopers at3, just dont want a wider tire if I can help it as the Cooper's are wider than the stock.
