I don't know about the clearance, but they are about an inch taller than what is stock and will throw your speedo off about 3% or so.
That is pretty much the same diameter tire I'm running (see sig). It should fit, but it comes pretty close to the strut spring base on the rear struts.
That part of my sig is the supplier of the sumpguard I'm using.
The last line of my sig is the tires. You can see them at www.Tirerack.com
