I have a 2022 Touring, and I just can’t get the battery to a full charge. Anyone else have this issue? I understand there have been some problems with the past Subaru batterIes.
See the dealer, here is a thread on the battery issue: ('14-'18) - 2018 - Battery lawsuit - anyone...You are most likely correct on the possible bad battery. It shows over 14 when running, It’s when I trying to give it a boost with a small charger/maintainer. Next time it’s in the dealership I’ll have them check it. The battery has a sticker “for start/stop” IS there a difference to this battery vs others?
Yes there is. Most automakers us an AGM battery for their start/stop implementations.<snip>
Did exactly the same thing. Not an issue and car cranks and turns over faster. Please note that I manually disable S/S each and every time I drive the car.My personal opinion: The factory batteries were crap. I had to replace one for a Crosstrek when the car just went out of warranty and I get a Walmart AGM for preventive measure especially with auto stop/start on the SK.
I am not clear what the problem is. Is it not accepting charge from the battery maintainer? Or is the problem that you expect it NOT to need further charging? If the latter, that's the nature of the system. My 4 year old battery has rarely finished the day at what I'd consider a 100% charged state, yet it soldiers on.You are most likely correct on the possible bad battery. It shows over 14 when running, It’s when I trying to give it a boost with a small charger/maintainer.
Simple solution.We are considering one last trip to Germany, and I have no real faith in either car lasting 30+ days in an airport parking lot.
Why do you think every summer the local parts store parking lot is full of cars waiting for their batteries?Understood. But I really am curious how your battery will do. The engine bay still get pretty hot (much hotter than ambient). Not sure the difference in ambient vs under the hood is relevant?
Remember that a 2018 does not have AS/S. The load conditions and recharge management is completely different. So comparison may not be valid to the OP's situation.My 2018 Forester resides in southern Arizona which is even hotter than bman400's Texas. I installed an AGM battery under the hood about 16 months ago. So far the AGM has performed flawlessly.
