2021 Forester Premium
Hi all,
First boo-boo for our almost-new '21 Forester: I managed to damage our right rear tail light (where WERE you, RAB!!??) Anyway, I ordered the replacement part but discovered that it does not come with the wiring harness. No problem - I'll just remove the harness from the old taillight and reinstall it in the new.
The amber turn signal is no problem as it is an incandescent bulb and is designed to be replaced, My concern is the two remaining connectors: the light grey wiring harness connector clipped to the lamp and the rubberized connector to the main LEDs in the assembly.
I'm concerned about breaking a clip or pulling wires out, so what would be the best way to remove these parts carefully and correctly
Thanks!
Motor vehicle Hood Gas Auto part Automotive exterior
Update #2: the repair is done. You just need a pair of long nose pliers to gently depress a tab on the LED connector to remove it, then to gently squeeze the plug underneath the harness connector platform to release the connector.
