1 - 20 of 33 Posts
2020 Forester
I am about to start a minor sound deadening project on my 2020 Forester and thought others might be interested to follow.
My previous vehicle was a BMW and was quiet on the highway, I obviously knew I would lose this going to a Forester but even so the noise level seems excessive especially coming from the doors/windows and the wheel wells.
I am going to install sound dampening pads to all of the doors by taking off all door panels and installing on all the bear metal, then I am going to spray a rubberized spray underneath all the wheel wells. The rubberized spray is not made to reduce sound specifically but does reduce it as a secondary benefit and it is cheap and easy to do.
I am only adding sound deadening material to the doors and possibly other easy to reach areas because I do not want to get all of the carpet out of the ground, that is a pretty big project from what I have seen. Door panels are easy to take off.
Expecting the doors to take about 45min each ( take door panel off, install matts, door panel back on)
Wheel wells 45min each first layer (taking tire off, cleaning, dry, spray) Wait an hour between each layer, doing two layers.
Again, I am well aware this is not optimal but if I can get just a 10% decrease in noise that's a victory for me.
For the low time commitment, room for mistakes/easiness and low cost I am hoping it will be worth it.
Planning to be done by mid July and will post results by end of July.
2008 LL Bean (4EAT)
If you think any of the noise could be coming from tires, they would be easier but costlier to change.
I thought my 2008 had too much road noise when new, and it mostly came from the tires. At 3,500 miles I sold the OE Yokohama Geolandars and replaced them with Michelin Primacy MXV4, which made the car quiet.
Even with the old frameless windows, I find the 2008 Forester to be as quiet as our 2016 Impreza on the road.
2020 Forester
@vintage42 Ya, tires to make all the difference. I still have the stock Ecopias on but i am going to upgrade those to TOYO At 3s next year which I know wont do any favors for tire noise lol.
In this case the spray on stuff is more just an experiment, if it lessens just a little then its worth IMO, we shall see!
2017 Forester 2.5 Premium, Black
@LukasB Options?
For sound deadener I used: a peal n stick rubber flashing w/foil backing Lowes/Home Depot (cant remember the brand, blue packaging)
For speakers (2017 Forester): fronts Sony XS-FB6930 6"x9"
rears Pioneer TS-G650 6" round
dash tweets: Rockville RTS silk dome 1"
These speakers were inexpensive and efficient/sensitive (can drive them with stock power).
Note: looking at the stock speakers for the 1st time will make you laugh out loud.
Keep in mind for the 2017 I also got various adaptors and wire connectors.
@LukasB welcome to the forum from Oregon!
Please complete your "Public Profile"! Not completing your Public Profile could result in your thread(s) being closed... locked or your thread post(s) being deleted!
19' Limited
If noise is at all an issue AT tires are not a great idea imo. I got the terrain contact at since they are supposed to be the "quietest" at tire, but I found they are still pretty loud and went back to an all season. They are great in every other way though. I did sound deadening on doors, trunk, floors, and the tires still made the biggest difference. I didn't rubberize the wheel wells though so that might be worth trying.
2020 Forester
Discussion Starter · #11 ·
All finished and here are the results
Did testing before and after at the same speeds and same stretch of highway on the way to work, all conditions the same.
Before dba lvl was 71.3
After dba was 66.8
So only like a 7% difference the phone is picking up, but as a driver and passenger there is a bigggg difference.
The sounds that do come in are much less harsh to the ear, it also makes the stereo sound much better and more clear.
Big improvement to noise in the back seat, actually recently got complimented from a friend sitting in the back how quiet it was .
I also did the spray on rubber liner in the wheel wells. Although I think it decreased tire noise a little bit its main benefit has been driving on gravel roads. When I kick up rocks its no longer sounding like they are clanking off of bare sheet metal because that is basically what it was in the wheel wells, so well worth doing that IMO.
Overall really easy project, taking the door panel covers off is easy and easy to put back on. Took me start to finish 30min each door, more like 50min for first door as I was figuring it out.
rear seat only took 30min and the spare tire area only line 20min.
Spraying the liner in wheel wells was super quick- cleaning took the longest.
I didnt get too detailed on covering every square inch I could, I just made sure to cover most of the big naked areas with material.
Overall need about 25 sq ft of material to complete project doing the doors, under back seat and spare tire space, I way over purchased.
and for the wheel wells need 1 can per wheel to do 3 thin layers.
Materials listed in first post.
2020 Forester
Discussion Starter · #12 ·
Results have been posted!
2009 Forester 2.5x 4EAT
After dba was 66.8
Decibel is a log scale, so from 60dB to 70dB is a doubling, just like it would be from 10 dB to 20 dB, or 100 dB to 110 dB. So 7% number reduction, but a whole lot more to the ear.
2021 Forester Premium
If I may ask, where did you learn how to remove all the interior trim, door panels, seats, carpet and so on? While I have sound deadened other vehicles in the past, I am a new, first time Forester owner and not too sure how to remove all the interior parts in this car. Thanks
2020 Forester
Discussion Starter · #17 ·
So I ONLY did the door panels, under the bench seats and where the spare tire goes and for that I just looked it up on Youtube, plenty of videos,
There was not really any videos when i was looking on how to take the roof liner off or the floor carpet, honestly even if there was not sure I would put that much work doing it lol, I would be scared of messing the roof liner up.
2021 Subaru Forester
To spray the wheel wells, did you remove the tires, or just spray up in there? Edit: missed the wheel removal bit in the above, as looking at the photos.
Spare tire well seems easy, under the rear seats bench seems easy, doors... pulling off the inside trim seems easy, but the sealed plastic sheet, removing (or rather replacing that) seems like it would be messy/difficult?
I know this thread is semi-old, but I had some question before I start my own project, inspired by this one, and at the same time upgrade my oem speakers.
In the door panels, did you pull off the transparent plastic used to keep moisture away, and if so, it looks like a pain to replace/reinstall? I saw some videos that seem to say you can reach everything from the speaker hole, but that looks not-so-easy.
For deadening I'm following your example, and do doors, under rear bench, under the spare donut and foam in the truck, and possibly rear hatch.
1 - 20 of 33 Posts
