As a lot of you seem to have a lot of knowledge on this subject I’m hoping you can answer this for me (in simple terms). Just bought a 2020 forester without the HK system. I am looking at adding a powered sub. I would like to tap into the rear speaker outputs to run the high to the sub. I have looked everywhere and cannot find a diagram outlining wire colors for the new cars. So now for the questions.
1.) will I run into this same starlink problems people are reporting by using the rear speakers instead of the front? (No speaker amp here so I’m not adding extra back into the system)
2.) I popped the grauments on the rear doors and it seems as if there are 3 speaker wires going to each speaker. These are the exact same color on both sides. Obviously I only need the+&- so any clue as to which of these would be them and how to tell them apart at the back of the head unit? Each door contained 7 wires yellow, green, black, and red were all around 16-18 gauge wires and (I’m assuming the speaker wires) each door contained purple, pink, and grey That were all around 22 gauge.
