1 - 20 of 30 Posts
The trip odometers on my '19 Fozzie are always "counting", even if they are not selected. For example, if I reset them both, then select "A", and drive 10 miles, "A" will show 10, but if I then select "B", it will also show 10. B should show 0, since it had not been selected since it was reset.
They worked OK at first, but at one point I reset them both and since then they've been doing this. I have tried various combinations of reset & select, but without change.
The car is brand new and under warranty, but if I can fix this on my own I would rather do that than take it to the dealer.
Thanks,
Bob
I think that’s how it works on most cars. My issue is it reset every 10000 miles and so with mpg calculation
2017 2.5i Touring
Now all I have owned are Subaru vehicles, but as far back as I can recall with regard to trip meters with dual counters, that is how they have operated. As for my usage, I would designate one of them for a long measurement and the other for shorter or incremental measurements.
Thanks,
Bob
I have never encountered a vehicle with dual trips that operate the way you think it should- there is nothing to fix. Have you actually thought this through? Whats the point of a trip odometer if it has to be selected to work? Why have 2 if one only works when it's selected?
As mentioned already, most people use one for current tank and one as overall.
... Have you actually thought this through?
Well, yeah ... I only posted because I wanted to use them independently.
Whats the point of a trip odometer if it has to be selected to work? Why have 2 if one only works when it's selected?...
Here's the point: you can keep track of specific activities. You can reserve one odometer to record business miles or charitable activity miles (necessary for taxes) or whatever to want to isolate. Only want to record those miles when doing that thing.
Rainlake, elDubDub - thanks. I guess that I can live with it. Not much better than my '92 Volvo & keeping track in a notebook.
I guess that I was wrong about "They worked OK at first"
2017 2.5i Touring
I can certainly see your use case, and possibly a suggestion for an option!
2018 2.5i Premium CVT
I use A for fillup mileage, and B for specialized trips, recording business mileage, etc.
Discussion Starter #11 (Edited)
Here's another cool use for independent odometers: use A for highway and B for off-highway. Then each would accumulate total miles on and off and would give you a cumulative and real-time MPG for each. Which you can only get currently by writing down each on & off highway mileage and MPG, calculating the gas used and adding it all up.
For your business mileage, it's only good for one trip. If you want the mileage for a month, you have to add them up "offline".
Correct. I have to write it down when I get home. But it saves me the math of recording start and end miles for the trip.
All the use cases can easily handled by use your phone. That been said, manufacturers really should keep up what drivers want, like Tesla do
My 2020 has the dual system and I find it useful as I use the "A" for tracking distance between fill-ups and "B" for short trips between fill-ups. As I've only had the vehicle a few weeks I'mm still playing with the various displays and have noticed that if you select one, say "B" it shows up on the display on the upper dash and then when you reset it it zero's the gas consumption etc so you can see what your getting on that portion of the trip while retaining the "A" distance for overall. I find it useful but then I really like gadgets.
Thanks,
Bob
You reset both, now both are runming. Then if you want to see how far itis to the grocery store simply reset B to zero. A will tell you total miles since reset, B will also show you miles sinc you reset B.
Discussion Starter #18
You reset both, now both are runming. Then if you want to see how far it is to the grocery store simply reset B to zero. A will tell you total miles since reset, B will also show you miles since you reset B.
Sure, but there's no way to see how many miles were driven to the grocery store this month. I.e., a running total.
1 - 20 of 30 Posts
