Thanks for the info from both of you. I am getting a Base Model soon and want to tackle the fog lights install on my own since the dealer install cost is pricey. I am okay with either set of fogs, but would like to have the matching color between the headlights & fogs meaning I will need white LEDs either way for the fogs. A few questions since I am a newbie with LEDs...
Simon - I look forward to your write up on the install. It does not sound difficult with the Subaru fog kit, but I will send you a PM for the install instructions. With this basic kit, the fog lights would be halogen (yellowish) while the headlights are LED (white), correct? Have you had any success finding an LED replacement to the fog to match the white color of the headlights? Do you think the install on the LED fog would be a simple plug & play or require additional wiring? The Fog Light Kit looks like it goes for around $220 or so online. Any approximate ideas how much the fog LEDs would go for?
Forthewife - impressive work almost getting all the parts to match the Sport LED Fogs. I like the look of this, very modern! I know you are still finalizing the switch part, but can you summarize the list of parts you needed and the approximate cost. Do you think this install is significantly more complicated than the fog kit? My guess is the answer is no, but not sure of course. Is there additional wiring needed for the sport version of the fogs?
I appreciate any additional info you both can provide. Honestly, I think many Forester buyers could benefit from each of your summaries/write-ups on your experience with the parts and the install. Thanks for all the info provided so far!
