How do you remove a radio prefset to "blank" again? I can't seem to find the info in my quick look paper. 104.3 HD 3 is now gone, not replaced, just turned off the signal. Would like to remove it.
Thanks.
The problem with just making another one over it is that I would have one station twice, so when I use the steering wheel controls, this would result in an extra button press. The ideal solution would be to clear it out, but I don't really want to reset the unit.
Well, no, what I would do is just move the other pref set over and then clear out the last.
After snooping around a bit and checking with the Ascent forum (they have the same infotainment system) I decided to just reset the unit.
All's well now, took about 5 minutes, but since you're clearing out the driver profile don't forget any other specific settings will be cleared out also.
