21 - 40 of 42 Posts
I also ended up getting the Ecohitch, and installed it the other day. Went slow, and took about 3 hours overall. The most difficult part was removing/detaching/reattaching the muffler support, which took some amount of grunting and judicious use of four-letter words. And even with the muffler lowered, it is awkward to work in the cramped space between it and the frame. Overall, very satisfied with the end result though, and would recommend this product!
2019 Sport CVT
I'm new to this forum after spending years on the XV forum. I have had 2 VXs, my kids now drive. Decided I need more room and liked the redesign of the Forester so I picked up the 2019 Sport in December.
First thing it need was a hitch and this thread with the fact my dealer only had the 1.25" available and wanted $900+ for the hitch installed, sold me on the 2" EchoHitch. My install took 3.25 hours to install with one issue. The nuts would not grab the studs with all the washers installed. There was a gap between the hitch plate and the body. I think the hitch was slightly over bend (reduced radius). Also could not snake the bolt into the driver side until the back bolts were tight. Took a little pattern torquing and loosening to draw the hitch to the body.
The end result looks and works great. Much better than the Curt I installed on my XVs. But I was able to get 2 Curts for the price of one EchoHitch.
When I went to order the hitch the picture on EchoHitch website didn't match the one shown on this thread. I asked for the installation instructions and low and behold THEY ARE IN COLOR. Real easy to see what needs done. Hope the attached helps anyone with their installation.
Does anyone have concerns about removing the rear bumper cross member and using the eco hitch in its place? From what I can tell from the installation instructions, the rear bumper bar is permanently removed after installing the 2019 eco hitch. Would this be a problem in a rear end collision?
2019 Forester Sport CVT
Won’t be an issue. The receivers cross bar is much stronger than the original cross member.
Raw,
What is your photography background? And what are you shooting with? Love your composition.
The one in the tall grass is awesome and makes me laugh too.
Nope, just take a lot of photos. Blind squirrel get the nut, as I have a huge SD card. Sony with 1" sensor. RX100
Cellphone for the simple quick shots.
Oh nothing, just the Sony RX100 which has been the best P and S for years. I know a few pros that use it for unobtrusive candids thanks to the flip out viewer.
I own one too. Got tired of carrying the camera bag and 3 lenses during family vacations. Love just slipping it in my pocket and going.
2019 Forester Limited
Just finished installing this yesterday.
Newbie here and took me longer than expected.. about 4-5 hours. But mostly because of lack of tools, I rant to the store no less than 3 times :lol:. Looks great installed. I think if I had more familiarity and all of the tools, could've knocked this out in about 2.5 hours or so.
Things that I needed in addition to what was listed on the front page:
- ended up needing a socket extension - 5" at least. My torque wrench was too bulky to fit between the cross bar and the actual bolt. So needed an extension to help break it as well as torque it appropriately.
- Needed a 19mm deep socket for the bottom bolt. The bolt adjacent to the muffler was not fun. You can certainly get it done, but wouldve been much easier just to take the muffler off.
Ultimately the thing that took me the longest was because of the above - just difficulty getting the bolts/cross bar off and then difficulty getting it torqued appropriately. Everything else was a breeze.
Did the install of the Ecohitch on my 2019 touring today. Because of all the great info on this thread it went like a breeze. I bought the 2" version as my bike rack and stuff are all 2". I highly recommend the Ecohitch and doing the install yourself, l saved a ton cash doing it myself. Bought some cross bars and had the front door windows tinted, which add to the look. Its great, I'm enjoying my forester.
Oh, meant to tell you guys, easiest way to remove muffler mounts is with wd40 and a piece of wood, like the end of a hammer handle, just push & pry, comes off so easy.
Regards.
Why wreck to look of your Forester with a big honking hitch?
https://***************.com/select-ecohitch-size
All you see is the hitch receiver. The heavy duty hitch frame replaces the wimpy bumper support.
$315.99 delivered.
2" Euro Curt ball with 2 3/4" rise. 3,500 pound hitch and Euro ball.
Nice tires. I can make out that they’re BF Goodrich, but what size and do they fit on a stock setup without rub.
2008 Forester Sports XT 5MT
5. The crosspiece support is held on with four 14mm bolts and two nuts. This piece is not reused but I saved it for any future accident. Removal exposed the car frame that the hitch fits into.
What do you mean by "saved it for any future accident"?
Thanks for the detailed install info!
2020 Subaru Forester Sport - Ice Silver Metallic, Option pkg 24.
Anyone know if the this particular hitch install affect the rear auto braking feature?
Thanks.
No it will not. I have actually used this feature after install and can confirm. In fact, the sensors are in the bumper cover and not affected by installation at all.
a question, comment, and Thanks to the OP for this thread!
Q: if the main use of hitch is for light recovery point, can the 1 1/4" size be put to use? (saving weight & $$$)
WD40 should Not be used with rubber/ similar material. use pure silicone or dishwashing detergent.
2019 Forester Premium CVT
I used a Rockwell F80 Oscillation Multi-Tool to cut the notch in the bumper cover. Made for a quick, clean and accurate job.
It looks like the rear recovery point is built into the bumper beam that gets removed when the ecohitch is installed. Does anyone know if the hitch can be used as a recovery point instead? If not, any suggestions how to rig recovery straps on the back if needed?
2020 Forester Touring
Just put an Ecohitch on my wifes 2020 Forester last saturday, pretty much went on as described. The only real issue, aside from taking apart a brand new car, was torquing the bolts that are in the frame. I needed to use a long extension to get the socket on and have room to swing the wrench. Couldn't get the wrench to click, so I just got them RFT(Really F** Tight) and called it a day. I also had the idea to make a card board template of the cut out of the bumper cover. It was easy making the cut out pattern on the flat bench and aligning it on the center mark of the bumper and tracing around it, than trying to mark the shape on the bumper cover directly.
In the end, the wife is happy she can put the bike rack on her car.
21 - 40 of 42 Posts
