41 - 60 of 126 Posts
2019 Forester Sport CVT
Discussion Starter #41
Glad it is working out for most people. Gumbobtr it looks like an error in the listing. I don;t think teh Touring comes with any options. It should have the 8" Nav display with HK system. No other options are available from what the website shows.
2019 Forester, Touring CVT
Yes Scott, and I see that even ordering the part listed for touring it shows the HU without NAV.
Hey folks, not sure if you are all aware, but there was a new software update released last week. You can follow the instructions on the bulletin to download the file from Subarunet.com. Appendix A details all the updates for this software version.
Be sure to download the correct file. There is one for Gen 3.1 Base (4 speaker), Mid (Premium 6 speaker) and High (HK 9 speaker).
I downloaded tonight and will upload and try it out in the morning.
Attaching bulletin.
Will this update itself if I'm connected to Wi-Fi? My car checks every morning but says I'm up to date.
2019 Forester Sport Rubber band
Unless something has changed very recently the Wi-Fi update feature is not enabled yet.
2019 Forester Sport
The update worked perfect for me with one exception...... on the SXM screen "Scan" did not change to "Tune Scan" it remained unchanged at "Scan" The system info confirmed the update version and everything works perfectly .... no more lost FM stations !!. Many thanks to Sdcerreta for posting the files and instructions. Did anyone else have the "Scan" button in SXM remain unchanged after the update?
2019 Forester
I have a 2019 premium with stock unit. No nav. Is this just a nav update or for all headunit it’s and what if any features are updated
Discussion Starter #47
All the info you need is in post #1 attachment. Once you determine which file you need you can download it. All the stuff in the update is listed in the appendix of that file in post#1.
2019 Forester
Does it really take 60 minutes to install. Does it provide progress? did you folks just sit there with car in idle?
Discussion Starter #49
No. Not for me. It took about 8 minutes maybe 10. That’s for the installation of the software. Then you have to perform several hard reboot which takes another 15 minutes collectively. You do not need the car running for that period of time.
2019 Forester Sport Auto
I just completed the install successfully had to format the USB as FAT32 using a PC with WIN 10. Initially tried Linux machine and had problem getting head unit to recognize the USB that was formatted on the Linux system.
Thanks for saving me a trip to the dealer. Saved at least half a day that I can enjoy.
2019 Forrester Touring CVT
The touring has the high sound system standard.
2019 Forester Touring
Something I’ve noticed since the most recent update in my Touring model with NAV... certain roads that used to display the posted speed limit in the earlier version no longer do so.
It’s no biggie, but just a bit odd. Otherwise, everything has been working well under the new update...
2019 Forester Sport
Found this thread thru. a Google search and wish to thank OP and others for the information about the software updates :)
Updated and worked flawlessly! Downloaded patch to thumb drive, started up the car and installed in about 5/6 minutes. Thank you!!
Same here.
Edited to note that today I find that the map is not showing location at all, and any attempt to navigate to any address shows "Route Calculation Unsuccessful."
In addition, the display at top of center of dashboard no longer shows street name, only compass direction.
Same here.
I’ll check my system to see if it mimics yours and post the results here later...
Same here.
I’ve checked out my NAV system to see if I have the same behavior described above after the latest update.
I’m not seeing any of the issues listed. Street names show, and the NAV system calculates routes in my 2019 Forester.
Perhaps the update in your vehicle didn’t complete successfully...
Thanks FelineFreddie. Yes, as it turns out, I had to reinstall the update and it seems to be working properly since the reinstall was completed. I just hope it won't require periodic reinstallations.
But thanks again for following up on it.:)
