1 - 15 of 15 Posts
2019 Forester
Does this happen to you all the time as well?
Stupid front part of trunk cover in the 2019 keeps falling off.
523166
So I designed a solution.
523167
It can hold the front part without a problem.
523168
Installed. It ain’t going anywhere now.
523169
Great design! An elegant solution to an persistent issue. How does it perform with the second placement point that allows for the rear seats in the recliner position?
2019 Forester
It’s designed for this one point only since you need the bracket to push against the cover itself.
2019 Forester Sport Auto
Two things:
1. How about making a shorter version for the recline position? Or figure out a way to combine it into one with two positions.
2. How about posting the 3D printer files?
2019 Forester
Discussion Starter #10
1. The bracket works by applying pressure against the rear cover part material.
I can design a bracket that will work with the second position.
2. It’s not 3D printed. It’s laser cut so my file is useless for 3D printing.
2019 Forester Touring CVT
Uggggh that little flap always falls! Great solution!
I don't think I've ever seen the cover in place, except when I have just put it back... I am also interested in a pair, Zoti, if you decide to make some.
1 - 15 of 15 Posts
