So here is the pin out for the American version of the MFD. What you are seeing is the following:
Pin 15: Green (MFD SW+)
Pin 19: White (CAN-H)
Pin 20: Black (CAN-L)
Pin 21: Black (Ground)
Pin 23: Red (Ignition Power Supply)
Pin 24: Yellow (Battery Power Supply)
I connected my wiring harness and was able to get the diagnosis menu to detect the camera through pins 2 and pin 3, the only bad part is I was not getting power through pin 1 and pin 4 to power the camera.
The resulting screen during front view monitoring adjustment was this (black screen cause no power)
I was able to hook the camera up to external power and get it running just to trouble shoot.
I double checked that pin 1 and 4 had connectivity from end to end using a voltmeter. Then I tested for power using a voltmeter and noticed I wasn't getting any. This led me to think about the following.
It seems that the display itself gets power from pins 23 and 24. This seems like enough power for the screen but thats about it.
Then I looked at the wiring diagram label again. I looked at pin 5. It made me wonder if that pin is the pin that carries power from the wiring harness to the MFD for the camera, then the camera goes about pushing it out through pin 4 to the camera.
Long story short, American models might not have the power support for the camera. I'm going to research the european pictures to see what their pin out looks like. If anyone has a picture of the pin out of an mfd plug from a forester I'd love to see it. I'm going to go look at the previous posts cause I remember some from those.
@subidriver @zachavm @InnocentSmith @denissh @CzechFozz
