Started my install today. Got mostly everything I need here on hand with more items to arrive within a week or two. I started with the rear door speakers and Dynamat install.
For those that haven't taken their Forester apart yet I will show what I did to get the rear door panels off. These three areas highlighted are the first things to do. Photo below.
You need to pull your door handle and use your plastic pry tool at the bottom to release the cover. You will see a small gap when you pull the door handle near the hinge. Remove the phillips screw and place it somewhere safe. I use the cup holders. Photo below.
Next use your plastic pry tool to pop the little plastic cover in the door closure area. I'm really not sure what to call it. Once it's popped open you can either remove the little tab or leave it in place. I chose to remove it. Just give it a little wiggle and it should pop out. Remove the screw and keep it safe. I will mention now that all the screws you are going to remove for the door panel and also the old factory speaker are all the same screw so there's no need to separate them all. Photo below.
Next you need to remove the little sail panel. Stick your plastic pry tool in between the plastic and the metal of the door about halfway up and pop it off.
You can either use your pry tool or your fingers to release the clips from the bottom of the door frame working your way up to the top on both sides. Once you have released all the clips gently lift up on the door panel because it hooks in at the top by the window until it is free. Don't move the door panel too much at this point because it's still connected with the door lock cable, the door latch cable, and a small wiring harness plug. Undo these three attachment points and your door panel will be free.
I pulled the plastic off of mine because I'm doing Dynamat.
Check out this horrible factory speaker. It is sad that this whole speaker unit was designed as a speaker and a bracket in one unit but it's just so weak. A couple extra dollars during manufacturing could have produced a much better sounding speaker. Shame on you Subaru.
Notice the plug there for the factory speaker. Unless you plan on soldering wires to your new speakers, I highly recommend you pick these up. These work for both front and rear door speakers. They plug right in to the harness that went to the factory speaker and give you an extra several inches of wire. The dash speakers require a different type of plug. Those are still in the mail I hope to get them soon. They were backordered.
Different trim levels seem to have different color wires at the speakers. In my case purple is positive and the other color is negative. You won't need to worry about that if you get these metra speaker harnesses.
