1 - 7 of 7 Posts
2019 Forester Sport
2019 Sport with about 18k miles. So far the mpg display has been reasonable. Yesterday it starts varying from --.- to 99.9. I think it would have gone higher had it enough digits. No other issues AFAIK. I reset the A trip display, no change. Has anyone else seen this?
2019 Forester Limited
Bad sensor or intermittent connection. Time to see the dealer.
Assuming you're not confusing the real-time mpg display with the average MPG display. The former continually updates and can display 99.9 from time to time.
2019 Forester Sport
@boureesub It is the real time. However it has not gone to --.- at every stop or bounced from there to 99.9 over and over and over...before.
2019 Forester Sport CVT
That sounds normal. In case of a problem, you can do a hard reset by diconnecting batt ground. Wait 30 seconds then reconnect. See if the problem resumes. If so, then it is likely a normal function.
2019 Forester Sport
If so then it is a new normal. It has never gone to --.- every time I stopped before. In any case I'll try the battery disconnect. Thanks
2019 Forester Sport
Looks like...no, this IS an I.D. TEN T. (Or id10t) problem. Either there is a ghost in my car or my hands have been multitasking behind my back. I apparently cycled the display without knowing.
1 - 7 of 7 Posts
