1 - 7 of 7 Posts
2019 Forester Premium
Hey Alll!
I had to tear out my heater core assembly on my 2019 Forester due to a cracked drain pan. To accomplish this I removed the dashboard and pretty much everything up to the fire wall. After changing the broken part I assembled everything and attempted to start the car, no start or crank.
Here are a few things I noticed:
  • Red led strip around ignition isn't lighting up
  • AC/ Heater doesn't turn on when in ACC mode
  • Engine not even trying to crank
yes, I had battery disconnected the whole time I was disassembling and assembling the car.
I hade some leftover connectors I cant seem to figure out where they go. I have a premium model so maybe they're for some module I don't have installed? or maybe this is contributing to the issue?
Please see photo of connector below. Any help is appreciated!
2021 Forester Premium
here is the diagram of connector behind dash board - driver side, hope this help
555266
Connector​
Connecting to​
No.​
Pole​
Color​
Area​
No.​
Description​
AB2​
4​
Y​
C-4​
Roll connector
AB35​
2​
D-4​
F/B
AB66​
2​
B​
C-3​
Driver's knee airbag module
AB75​
2​
C-1​
i302​
Short connector
i5​
16​
L​
D-4​
F/B
i10​
40​
B​
A-4​
Combination meter
i19​
14​
A-1​
R96​
Roof cord
i28​
4​
C-2​
OP connector (fog light switch)
i47​
7​
B​
B-4​
Steering lock CM
i52​
2​
B​
B-4​
Key lock solenoid
i58​
8​
B-4​
Ignition switch
i60​
5​
C-4​
Immobilizer antenna
i63​
2​
C-5​
Key warning switch
i68​
7​
B-5​
Combination switch​
i69​
10​
B-4​
i72​
14​
C-4​
Roll connector​
i73​
20​
B-4​
Combination switch​
i74​
5​
C-4​
Steering angle sensor​
i75​
28​
B-3​
Keyless access CM
i79​
6​
C-2​
Illumination control switch​
i81​
32​
B​
D-5​
Body integrated unit​
i82​
18​
B-2​
J/C​
i84​
10​
D-5​
i94​
8​
L​
C-2​
BSD/RCTA OFF switch​
i101​
46​
C-1​
D84​
Front door cord LH​
i112​
86​
B-2​
B60​
Bulkhead wiring harness​
i115​
4​
Y​
B-2​
B49​
i136​
40​
Gr​
D-4​
F/B​
i137​
12​
Br​
D-4​
i140​
4​
A-1​
J/C​
i141​
4​
A-1​
i150​
14​
B​
B-5​
Push button ignition switch​
i157​
22​
A-1​
R50​
Roof cord​
i158​
4​
A-2​
Side tweeter LH​
i166​
4​
B-2​
J/C​
i167​
4​
B-2​
i171​
40​
D-5​
i173​
4​
B-5​
In-vehicle sensor​
i175​
6​
B​
B-4​
Air mix door actuator LH​
i176​
6​
B​
B-4​
Mode door actuator​
i215​
18​
B-2​
B129​
i216​
6​
B-2​
B130​
i234​
8​
B​
C-2​
VDC OFF switch​
i236​
8​
Gr​
C-2​
Auto Start Stop cancel switch​
i241​
30​
A-3​
Keyless access CM​
i257​
4​
C-2​
Memory height switch​
i258​
4​
Gr​
C-2​
Power rear gate driver's switch​
i265​
8​
D-4​
F/B​
i266​
12​
D-4​
i267​
2​
B-3​
Trip switch​
i275​
22​
B​
B-4​
J/C​
i277​
4​
Gr​
C-2​
SRH OFF switch​
i280​
5​
Gr​
B-2​
Steering heater/Seat heater relay​
i284​
64​
D-2​
R466​
Rear wiring harness LH​
i285​
48​
D-1​
R467​
i288​
16​
C-3​
Data link connector​
i289​
4​
C-4​
Roll connector​
i291​
6​
C-4​
OP connector (remote engine start CM) (without push button start)​
i302​
2​
C-1​
AB75​
Short connector​
i315​
8​
B​
B-2​
Fuse holder​
i346​
8​
G​
C-2​
Driver monitoring system OFF switch​
i352​
4​
B-2​
J/C​
i353​
4​
B-2​
GB-4​
D-1​
★:White or natural color
here is the diagram of connector behind dash board - driver side, hope this help View attachment 555266
Connector​
Connecting to​
No.​
Pole​
Color​
Area​
No.​
Description​
AB2​
4​
Y​
C-4​
Roll connector
AB35​
2​
D-4​
F/B
AB66​
2​
B​
C-3​
AB75​
2​
C-1​
i302​
Short connector
i5​
16​
L​
D-4​
F/B
i10​
40​
B​
A-4​
Combination meter
i19​
14​
A-1​
R96​
Roof cord
i28​
4​
C-2​
i47​
7​
B​
B-4​
Steering lock CM
i52​
2​
B​
B-4​
Key lock solenoid
i58​
8​
B-4​
Ignition switch
i60​
5​
C-4​
Immobilizer antenna
i63​
2​
C-5​
Key warning switch
i68​
7​
B-5​
Combination switch​
i69​
10​
B-4​
i72​
14​
C-4​
Roll connector​
i73​
20​
B-4​
Combination switch​
i74​
5​
C-4​
i75​
28​
B-3​
Keyless access CM
i79​
6​
C-2​
i81​
32​
B​
D-5​
i82​
18​
B-2​
J/C​
i84​
10​
D-5​
i94​
8​
L​
C-2​
i101​
46​
C-1​
D84​
Front door cord LH​
i112​
86​
B-2​
B60​
i115​
4​
Y​
B-2​
B49​
i136​
40​
Gr​
D-4​
F/B​
i137​
12​
Br​
D-4​
i140​
4​
A-1​
J/C​
i141​
4​
A-1​
i150​
14​
B​
B-5​
i157​
22​
A-1​
R50​
Roof cord​
i158​
4​
A-2​
Side tweeter LH​
i166​
4​
B-2​
J/C​
i167​
4​
B-2​
i171​
40​
D-5​
i173​
4​
B-5​
In-vehicle sensor​
i175​
6​
B​
B-4​
i176​
6​
B​
B-4​
Mode door actuator​
i215​
18​
B-2​
B129​
i216​
6​
B-2​
B130​
i234​
8​
B​
C-2​
VDC OFF switch​
i236​
8​
Gr​
C-2​
i241​
30​
A-3​
Keyless access CM​
i257​
4​
C-2​
i258​
4​
Gr​
C-2​
i265​
8​
D-4​
F/B​
i266​
12​
D-4​
i267​
2​
B-3​
Trip switch​
i275​
22​
B​
B-4​
J/C​
i277​
4​
Gr​
C-2​
SRH OFF switch​
i280​
5​
Gr​
B-2​
i284​
64​
D-2​
R466​
i285​
48​
D-1​
R467​
i288​
16​
C-3​
i289​
4​
C-4​
Roll connector​
i291​
6​
C-4​
i302​
2​
C-1​
AB75​
Short connector​
i315​
8​
B​
B-2​
Fuse holder​
i346​
8​
G​
C-2​
i352​
4​
B-2​
J/C​
i353​
4​
B-2​
GB-4​
D-1​
Thank you. This is exactly what I needed. the 3 plugs are suppose to plug into the to top of the interior fuse panel right above i84. I plugged them in and everything works perfectly.
1 - 7 of 7 Posts
