Some work with plasti dip and color matched pinstripes. Also have don’t some carbon fiber trim covers inside and out. Let me know your thoughts and opinions!
Thank you! It’s an aftermarket shackle on the OEM tow hook with a metal spacer custom made so the shackle does rattle aroundIs that just a shackle on the OEM tow hook? Or is it an aftermarket shackle/tow hook assembly?
I like the work on the hood.
Thank you kind sir! I was fortunate enough to find vinyl pinstripes in the forester sport orange. Turned out better than I had hoped.Thats a cool take on the sports look! Awesome job!
I appreciate it! That car is my baby haha. Put a lot of time and effort into it over the last 2 1/2 yearsThat looks badass! Very nicely done. Love the front end shot.
Thank you!! That was one of the first modifications I made. Just the black OEM body side moldings!@ForesterMike86 Love it. Finally a pic of contrasting color Body Side Molding.
How did you do black door handles?
What about the black door handles? Did you have to open up the door and remove them to change the color?Thank you!! That was one of the first modifications I made. Just the black OEM body side moldings!
They are carbon fiber covers that I got on Amazon actually. Held on with 3m automotive tape that came with them@ForesterMike86 Love it. Finally a pic of contrasting color Body Side Molding.
Thank you so much! It definitely turned out better than I thought it would.That pinstripe with the contrasts makes a huge difference! Looks slick man amazing job.
that looks so sick, very well done.Some work with plasti dip and color matched pinstripes. Also have don’t some carbon fiber trim covers inside and out. Let me know your thoughts and opinions!
View attachment 559319 View attachment 559320 View attachment 559321 View attachment 559322 View attachment 559323 View attachment 559324
Thanks so much!!! I don’t have a separate post for my Hella set up but I got it from SubjMods.com. Come with all the wiring and bracket for attachment. I wound up leaving on the extensions that came on the back of the Hellas. I also have two more leads for two more horns on that harness the subimods provided 😏 Just haven’t installed the second set of horns yet.that looks so sick, very well done.
Do you have a post for your Hella setup? If not, what bracket/wiring harness combo did you go with?
Thanks in advance!
thanks!Thanks so much!!! I don’t have a separate post for my Hella set up but I got it from SubjMods.com. Come with all the wiring and bracket for attachment. I wound up leaving on the extensions that came on the back of the Hellas. I also have two more leads for two more horns on that harness the subimods provided 😏 Just haven’t installed the second set of horns yet.
Yes sir!!! That’s the one. Took less than 30 minutes to install. Wiring harness is top notch👍🏼thanks!
Is it this kit right here? Or the 2015-2017?
HP gain of 8.5+ and if I remember correctly over 9 ft lbs of torque. Throttle response is massively better as well as the exhaust not from my Nameless exhaustWow...
2 questions -
What will you gain from the AEM Induction set up
Are those full speaker covers with an open grillwork? Where'd you find them...!
