1 - 2 of 2 Posts
Hi everyone. I found a pair of 4 stock wheels/tires from a 2019 Crosstrek Premium for sale at a good price. I’m wondering if these will fit my 2010 Forester Premium. The stock Forester size is 225/55R17. The Crosstrek wheels are 225/60R17 (Yokohama Geolandar G91F). Any idea if these will fit on my car? Can anything on the car be damaged by doing so? Thanks.
2013 Forester XT
Those crosstrek wheels will have a 1" larger diameter (27.6") They will fit, your speedo will probably be a tad bit slower than actual speed. You may get a light bit a rubbing at full turn lock at either 9 o'clock or 3 o'clock of the front wheel wells on the liners.
I currently run the same larger diameter in a 245/45/19 (27.7") and it will occasionally rub in those areas. Might wheels are a bit wider with a more aggressive offest which might be causing the rubbing. The rubbing is very minimal and doesnt occur all the time.
1 - 2 of 2 Posts
