Assumptions : I notice a lot of guesses about what might cause dead batteries, but actual numerical data is almost impossible to measure; some ideas are very .... interesting, others ... not so much : but for everyone having problems with OEM or other Under-Powered Batteries not having enough CCA capacity to handle small every-day forgetfullness or problems, I'd very seriously recommend that you break the OEM-Equivalent Paradigm and become your own person : go for the "Highest" CCA that you can place inside the Battery Tray, and that is definately what is not OEM Recommended ! Go to whoever you "trust" and have your Battery temporarily removed from your Vehicle; then measure the dimensions for the bottom of the Battery-Holder-Tray (remember that all batteries are somewhat rounded at the Bottom, so they will fit in that last 1/4" { ~1/2-CM} that you think that you will need to give up on !). Then go to the Web-Site :
BCI Battery Group Size Chart and find a couple battery sizes ( aka, "Group" ) that will Physically fit in your Model, noting that some Groups come in Normal Post Configuration, and others come in "R" Sub-Groups ( Reversed Polarity Posts ). Make a sketch of your in-place Battery Positioning & Post Polarity when you go shopping, maybe taking your Helping-Hand Person with you. Your Goal should be to get an 800~900-CCA Replacement Battery. Also, you can verify how much taller a new Battery can safely be by placing a small stack of wooden blocks, or even Phone-Books on top of the existing battery, and gently closing the Hood on top of the Stack to see how tall a Stack can tolerate the closed Hood.... then reduce the Height-Number by about ~1" {or about 2-3-CM }. You should find that the Battery Case can very safely hold a new Battery at least 2" Taller ( ~5-CM ) and still safely clear the Hood; also, the Battery Clamp Hold-Down Srews ("bolts" ) are VERY LONG ! So they will also accomidate a taller battery by the same amounts that you might measure. After getting a 2X-3X Higher CCA Battery, most of your Dead-Battery-Issues should magically disappear !!!!!
