Wondering if the 2019 Forester can forgo the set of tires or new tire shave down when replacing a tire? I am led to believe other manufactures no longer have this issue due to fluid coupling AWD vehicles.:nerd:
Forgive my blunt nature- so one guy mentions his Audi not needing it- which you didn't bother to verify and then come on a forum and say it seems other manufactures don't require all 4 tires. That's a pretty good stretch.Guy I work with had 3 Audis with AWD. On the 3rd Audi he claimed no longer had to shave tires or replace a set of tires due to the fluid coupling. I am no expert so this is the reason I asked in forum.
Correction: I did not preach I was asking?There may be a 'fluid coupling' (aka viscous coupling) component in the CVT transmission, but the differentials have not changed on these vehicles so that the AWD is 100% safe from non-equal rolling circumference on a tire. Any potential issues of causing damage to the AWD system would arise after long term use of a non-equal set of tires, so it is something you (or your Audi friend) could get away with for a while. Long enough perhaps to preach about how new cars are immune to differing tire sizes... but I suspect Audi continues to use regular mechanical differentials and needs matched rolling tire sizes also.
Additionally, different rolling sizes of the tires make for a potential a safety issue in inclement weather. AWD and VSC dont need the added challenge of an unequal tire when trying to keep the vehicle straight in a dynamic maneuver or slick road.
Kinda far fetched, but I also would imagine an insurance company could void a claim in an accident where they find the vehicle was fitted with tires outside of the manufacturer recommendation. That liability is enough for me to not roll the dice on tires.
Fortunately Tire Rack (and others surely) will shave a tire for you if you call them and place the order. Have not tired this but got a quote; I got a screw in the sidewall of 1 OEM tire at 5,000 miles and despite adequate remaining tread to have one shaved and installed, I went with a new set of 4. In 2016 the OEM tire was garbage on the XT, and expensive ($200+) for a single shaved replacement, so a new set of Colorado capable tires was the best route. Tire Rack Tire Shaving
I suspect the reason the donut spare states to not run the spare for more than 50 miles, and no more than 55 mph, is to protect differentials from damage from that tire, I didnt measure when using it but theres no way that little donut is the same rolling circumference as the real tires. So its ok briefly to get home, not good as a long term plan IMO.
Pull quote from a Tire Rack article:
"Four-wheel drive and all-wheel drive vehicles are equipped with additional differentials and/or viscous couplings that are designed to allow momentary differences in wheel speeds when the vehicle turns a corner or temporarily spins a tire. However, if the differentials or viscous couplings are forced to operate 100% of the time because of mismatched tires, they will experience excessive heat and unwarranted wear until they fail."
So viscous coupling or no, tires need to be of matched sizes
Not worked up at all, just genuinely curious how people make those stretches.Personally I see no reason for getting worked up about a question that I was asking. Please have a much better day!
That is one of the many reasons that education is failing because we are loosing the self reliance, the ability to do research and expand our knowledge beyond asking.During my education as a youth. Educators would say to the class. The only dumb question is the one that was never asked.
