Hi, anyone here has any experience with Yakima Exo Hitch system? I am about to install a tow hitch just to use Exo system, but not sure if it will fit. Does anyone have the measurement for these?
Thanks in advance!
Thanks in advance!
@Menel thanks man! but with the 150lb weight limit info, I can forget about it. I am not going to do it anymore... such a disappointment. I was dreaming to install the Exo system and go on an epic camping trip with my famil.ecohitch.
less than an inch in the rear.
10nch mark is in the hole count from wherever.
Goes straight back, under spare tire, no interference but close.
Lots of options, rooftop box?@Menel thanks man! but with the 150lb weight limit info, I can forget about it. I am not going to do it anymore... such a disappointment. I was dreaming to install the Exo system and go on an epic camping trip with my famil.
love that cargo carrier! thanks. I will look into this.You can still go on epic camping trips with the fam... Don't forget you've got a roof rack capable of a few hundred LBs (even higher for a Wilderness) and the rear cargo...
I use a cargo basket carrier and others have those 'coffin box' cargo carriers with spare tires and firepits and camping stoves and all of that... And you can still hang that 150 lbs off the back using a lighter cargo carrier option... Don't give up on your dream, just find a better way to make it work with your Forester.
For example, this cargo carrier for the rear hitch weighs in around 60 lbs and you'll still be able to load it with another 100+ lbs of gear.
The 2018 manual says the roof rack system is limited to 150 lb (cargo and accessories), the load limit of the cargo, crossbars, and carrying attachment can't exceed 176 lb, and the crossbars are limited to 165 lb. I'm not sure who proofread the manual. But, if you want to obey the numbers in the manuals, like you do with the tongue weight, make sure the manual does say you can put a few hundred lb up top.You can still go on epic camping trips with the fam... Don't forget you've got a roof rack capable of a few hundred LBs (even higher for a Wilderness) and the rear cargo...
Yea, a trailer would be nice, but I got no where to park itIf you really need the extra cargo capacity, and the roof just isn't enough, consider something like this:
Ultra-Tow Tag-Along Pull Behind Motorcycle Cargo Trailer Steel Frame, 16.6 Cu.Ft. Storage, 600-Lb. Load Capacity | Northern Tool
The Ultra-Tow® Tag-Along Trailer adds 16.6 cubic feet of storage space to your car, truck or motorcycle to carry up to 600...www.northerntool.com
Holy cow, with how much that holds it's almost not worth the trouble.If you really need the extra cargo capacity, and the roof just isn't enough, consider something like this:
I was going to write to Yakima on how they false advertise with Rav4, then out of curiosity I checked, if it's Rav4 Prime, it actually has 250 lb tongue weight limit. now we don't know if it's regular Rav4 or Rav4 Prime lol. The whole system in the picture is 166 lb by itself, two bikes, if they're carbon bikes, maybe 50 lb, that leaves little room for that gear box hahahI'm with FB.
I see Yakima demoing it with a RAV4 with double bike and storage bin... which also has a max 150lb Tongue weight. So Yakima isn't afraid to play it loose.
Toyota Mobility
www.toyotamobility.com
