1 - 2 of 2 Posts
2018 Forester ∞
Hi all,
Just a quick note:
I was working on a mystery task on my '18 Forester when I damaged a relay, "H/L RELAY HI" according to the fuse box in the engine bay.
I called the local dealership, was quoted $84 bucks for each relay. I looked online and couldn't get a clear part number to order. I then turned to Digi-Key and found the exact relay for $4.10.
Panasonic ACVN51212
This is just an FYI, in case you find yourself needing this relay, which is used in (4) different spots in the fuse box for a base Forester, hope it helps someone - thanks!
1 - 2 of 2 Posts
