We experienced problems with the car soon after routine servicing. Symptoms included stalling at traffic light, slow and hesitant/erratic uncontrolled acceleration. Took it back to the dealer. They did some data retrieval and found a mass airflow event. They cleaned the air filter, test drove and returned the car to us. The problems remained but this time the car did not stall. We took it back to the dealer. Also filed NHTSA complaint 11420905.
The dealer confirmed the concern. Per bulletin, 16-95-15R monitored TCM data during test drive and found at below 45MPH at wide-open throttle there was a rise/fluctuation in primary pulley speed and secondary pulley speed indicating CVT chain slip. They replaced the transmission with a remanufactured one. Test drive by the dealer and stated normal operation. There was no charge to us but the cost was estimated to be $11,000.
The problem has not gone away. The car still hesitates when the pedal is even gradually pressed and the shifting when it does happen is very jerky and abrupt. The availability of power when needed is questionable. The car drove perfectly well until this problem surfaced, so this is extremely disappointing. Not sure why a remanufactured CVT was installed in lieu of a new one? The problems appear mainly at speeds below 45 and highway driving while at speed seem normal.
We will be taking it back again but not sure what else we need to do and if others have faced the same issue for the 2018 XT.
