My FXT is barely 18 months old with under 18k miles. Everything's been great until 2 days ago driving to work in a mini LA heatwave (90F @ 9am) I notice the AC is barely cool. By the time I got to work it wasn't blowing cool at all. On the return drive I found that even with Dual control off, it was a little cool on the passenger side and not at all on the driver side (a very noticeable difference).
I took it in for service today. Told them I'd also noticed what looked like a fresh oil drip in the driveway (familar because it was at the same spot my old car marked frequently). I was told the condenser had a leak and it was replaced under warranty. The not cool at all(L)/a little cool(R) was explained that the right side vents are closer to the condenser so they got whatever cool air the damaged system could manage. No other fluid leak was found anywhere. AC works like it should now.
My questions are:
What could possibly cause 18-month old condenser to fail? The AC does get used a LOT, this is Los Angeles after all. Is this a common experience for new Subaru owners? Should I just chalk it up to a defect and be glad it happened now or be concerned that there's a likelihood of a recurrence after the warranty runs out? IOW, is Subaru known to have condenser issues?
Does the L/R temperature difference explanation before the fix make sense? I was a bit concerned there was an issue with the vent controls or airflow. All seems to be OK now but I've only driven the 15 minutes back from the dealership so far.
I know AC refrigerant evaporates quickly into the air when released but it does contain oil. Is it likely the driveway oil stain i saw was coolant oil? There's no way an 18-month old car should have an engine oil leak...
The FXT's been great to this point and I've been very happy with it. Hopefully, I'm just overthinking the condenser failure.....?
My questions are:
