2017 Forester Premium, 50k miles. My a/c was blowing 80 degree air at the top ouletlet so I took it to the dealer after reading about condensor leaks on this forum. Sure enough the condensor had a leak on the seam and the dealer confirmed its a common problem they see. The condensor was replaced (Subaru covered parts cost) and the system charged. The the problem is its not real cold and it seems to cycle more than my Honda or Toyota did. I measured the outlet temp on a 92 degree day, temp set to Lo, 3 bars on the fan speed and it varried between 45 to 55 degrees F. At one point it went to 58. Does this sound like its working properly and what should the outlet temp be, I've seen mention of 35 degrees F?
