MY16 Forester 2.0 XT
Hi
I'm unlucky with my Forester:frown2:
A few weeks ago the tyre pressure alarm lamp started randomly blinking upon car start without obvious reason (pressure in all tyres was perfect), then a week later keyless access system stopped working "just like that". From what I've read - it is the same module...
Does anybody know where the control module is located in my 2016 XT (without start button)? I could at least check connections and visually inspect electronics before spending $$$ at dealer to fix it...
Many thanks.
Thx. I will disconnect battery for several hours and see if it has any influence.
However, I dared to ask about control module location, just to check if maybe there's moisture or something... I could not find reliable information so far - service docs for Forester 2015 suggested rear right behind plastic cover, where in my car I only found fuel pump controller instead - that's why asking you gurus here :)
