1 - 11 of 11 Posts
2016 Forester AT
I'm planning to get a Tein H-Tech for my SJ paired with stock strut.
any thoughts on this combo? is it good for daily driving? and how is the ride quality?
any suggestions would be appreciated even with different lowering springs.
2017 2.5i Fozy CVT
How much do they decrease your ride height? I assume you will be getting a 4wheel alignment after,...
;) why do you want to make it harder to change your oil, get the car on ramps, and slow down more for potholes and speedbumps?
2017 2.5i Fozy CVT
There are some threads,, search tein for some insight.
I assume you want a harsher ride than stock if it gives you the look and performance you want?
What about larger rear swaybar, poly bushings?
2016 Forester AT
Discussion Starter #8
since you mentioned swaybars, what benefits would a larger swaybar have? I've read somewhere that they tend to use 19mm over the bigger one. why is that
1 - 11 of 11 Posts
