Does anybody know how difficult it is to replace a rear differential cover?? (see pictures)
I month ago I replaced the rear differential fluid and unfortunately overtightened the drain plug which cracked the cover just enough for oil to slowly leak.
I was getting ready to replace it (part is arriving in a few days) and was hoping the steps were:
1. Put some support under the differential
2. Unscrew the 2 big bolts holding the differential to the sub frame
3. Unscrew the 8 small screws holding the cover to the differential body
4. Put everything back together.
But as you see from the pictures, space between the sub frame and the cover is millimeters. So, i'm hoping one of you did this already and knows the steps. I'm really hoping "oh, it's super easy! and I don't have to tow it to the mechanic.
Any advice is appreciated.
I bought the replacement: cover, 8 small bolts holding the cover because they are super rusted, and the gasket.
Thanks!
Thanks!
