2016 XT
Please can anyone help me identify what color wire, in the door harnesses, powers the LED Approach Light?
  • I have existing OEM LED Approach Lights. These are built into the side view mirrors on a 2016 FXT.
  • I have removed the door card and back probed the 10-wire connector on the harness bundle going to the door mirror.
  • My back probing with a multi-meter did not give me a clue about which wire powers the LED Approach Light built into the top corner of the side view door mirror.
  1. Is said wire in the 10-pin connector for the red-wrapped harness going to the door mirror?
  2. Is it 12 volts?
  3. Is it 22 AWG gage wire, or other?
Thanks.
2020 Sport
Hey don’t know if you figured it out yet but the info is below
mirror harness connector - positive is orange wire
Negative is blue wire
car harness connector (what mirror plugs into) - positive is blue with red strip
Negative is orange with green strip.
2016 XT
THis is great news! I thought I had measured voltage every possible wire in the car's harness connector by back probing but apparently I must have not probed properly. Thanks. I will go & double check when it gets above freezing. I hope my 2016 FXT Premium wires are the same color as yours.
Thanks again.
2016 XT
AVEST & DEFROY wiring for their aftermarket puddle light is what I finally wired up thanks to Molsen's post. I coupled the SUbaru orange wire with the Avest/Defroy white wire. And I coupled the Subaru blue wire with the Avest/Defroy black wire. The aftermarket puddle light now comes on when I click the key fob. Sweet! I used Posi-Taps as recommended by DeFroy. Easy.
Which Subaru wire does the Avest blue wire for the DRLs or Day Lamps on the door/side mirror turn signal LED lamps connect to?
