1 - 10 of 10 Posts
2106 outback 2.0 diesel
Hi,
i am the owner of a 2016 Subaru outback 2.0 turbo diesel and am inquiring if anyone has fitted a catch can to one of these engines and can explain how. pictures would be good.
Stockss:smile2:
G'day & Welcome Mate!
I'll move you post to the technical section. Not sure about your engine but fitting a catch can is usually pretty easy. Just find the valve cover breather hose (which vents the crankcase and returns the air to the intake usually before the turbo) redirect that hose, or a replacement hose if not long enough, to a catch can and then the catch can outlet hose gets plugged back to the valve cover breather.
Here's an example from my Triton with a ProVent catch can:
The catch can is the black object just to the right of the radiator.
2012 SH Manual Diesel
Provent 100 catch can (sold as FlashLube Catch Can Pro). Had to make an external reservoir for it, as the volume it holds, wasn’t enough for what it was collecting.
528002
528003
1 - 10 of 10 Posts
