After a few day of drivings my wife said nothing is different for the old brakes but I feel the car brakes more responsive. She drives it more daily than me.. if the rotors and pad gives me another 50k miles just like the OEM i will probably just buy the one step down from Z26 and maybe a new caliper will do the trick next time. As far as The intake they been saying the it really does need tuning..
[/QUOTE]
What are you expecting from new brakes? If the new pads are soft, brake pedal pressure may be reduced and the pads will wear out quicker, and if the pads are hard, brake pedal pressure may be increased. Otherwise, the stock brakes have plenty of power to lock up all 4 tires at will and if you replaced the brakes on a new car with slotted/drilled rotors and performance pads, I doubt you'd see a shorter stopping distance.
Where performance brakes and rotors may help you is in repeated braking, such as doing laps on a road course or autocross course, or doing like a magazine tester and doing numerous 60, 70, or 80->0 stops consecutively. Good performance brakes will not fade as rapidly when they heat up.
Most performance brakes are sold for looks and advertising hype. Painted calipers look nice but don't work any better than unpainted ones.
