21 - 21 of 21 Posts
2020 Forester 2.5 CVT base model
The LO will appear weather the aircon is on or not. If the aircon is off, and the temp dial is all the way to the coolest setting, Lo will appear. Outside air is entering the cab at whatever that air temp is. ( Dash display indicates that). Turn the heat dial one notch allows a little heat to bleed into the mix, and LO is replaced with the new incoming air temp. Further dial notches sees the temp increase by increments.
So if outside air is 19 deg, and a little cool for you, the heat dial can be turned by notches until a comfortable temp is achieved. 21, 22, 23 etc.
21 - 21 of 21 Posts
