I just told you there is no difference in in viscosity (ability to flow) when engine is cold between 0W, 5W, 10W. Done trying to educate you. :cheers:oh so dont worry how oil flows when the engine is cold??![]()
It's the CAFE standards. I believe everywhere else 30 vis is called out.The real puzzling question, to me anyway, is why the different viscosity recommendations on North America engines and European or, not sure, the rest of the world.
While there maybe some slight component differences, the basic engine, pistons, bearings ect. surely have to be identical.
The manual for 2015 Forester instructs use synthetic (Mobil) 0W20 oil. Our 2015 with 75K miles burns several quarts between oil changes (at 7,500 miles per).
Might using a heavier oil help reduce consumption? Thanks.
I have a 15 2.5 premium with over 80,000 miles on it and use Castrol edge 0W/20 full synthetic with titanium that is designed for a hotter running engine and at every oil change it is just as full as when I filled it Also a good high quality oil filter is the real key to oil management. People hate them and people call them crap but I stay true to K&N oil filters. I have order them through amazon. Important fact here is do not ask advice at an auto parts store. Most of the time they know less than nothing.The manual for 2015 Forester instructs use synthetic (Mobil) 0W20 oil. Our 2015 with 75K miles burns several quarts between oil changes (at 7,500 miles per).
I have a 15 forester with over 80,000 miles where going up in the weight is not a good idea every engine is different my 2.5 is not the exact same as yours.could have been assembled in the same plant in the same day and will have little differences. Externally they are the exact same but internally Unless all the tooling is checked and torque tools calibrated after every time that tool was picked up or used, and no one accept high end sports car builders and racing teams, it just isn’t efficient. Tooling wears, torques very and people get tired. Although everything is in tolerance nothing is exact. You have to find what works with your engine. There are a lot of choices out there. 2 pieces of advice don’t use an oil because it says it is the best for it and do not get advice from a chain auto parts store. Find yourself a master mechanic and befriending him. Mine said to use castrol edge with titanium 0W20 full synthetic It is designed for harder working and hotter running engine. Also a good oil filter is key to oil management. A lot of people don’t like them, they are more expensive and I have to order mine but I use K&N oil filters. Could just be luck but my oil is just as full when I change it then when I filled it. Purealator is a good one too if you don’t want to pay the extra couple bucks for the N&N just stay away from fram.The manual for 2015 Forester instructs use synthetic (Mobil) 0W20 oil. Our 2015 with 75K miles burns several quarts between oil changes (at 7,500 miles per).
0w20 is the recommended oil in countries such as the U.S. and Australia which have fuel use standards. Elsewhere, 'heavier' weight oils are listed options. It has nothing to do with whether the engines have tighter clearances, etc, but government regulations. Subaru isn't making several different engine versions for different markets. It would be inefficient.why the different viscosity recommendations on North America engines and European
Thats what I figured.0w20 is the recommended oil in countries such as the U.S. and Australia which have fuel use standards. Elsewhere, 'heavier' weight oils are listed options. It has nothing to do with whether the engines have tighter clearances, etc, but government regulations. Subaru isn't making several different engine versions for different markets. It would be inefficient.
do I get a shingle to hang on a wall?? lol You are wrong... excuse me incorrect. No need to educate anyone but yourself.I just told you there is no difference in in viscosity (ability to flow) when engine is cold between 0W, 5W, 10W. Done trying to educate you. :cheers:
At -51 degrees 0w20 flows better, but if european & every where else the recommended oil was 0w20 I would agree that the engineers designed the engine optimal oil is 0w20 but when they specify other oil viscosity in other countries then I really feel like it’s more of a way to achieve fuel mileage increase than engine longevity!I would not second guess the engineers who designed the engine. Remember, that 0W-20 oil gets to the moving parts of the engine faster at startup, and the passages that carry the oil to the various moving parts are designed for 0w-20 oil. Using a heavier oil may starve moving parts at cold start time.
If you ever have a warranty claim, using oil that does not meet the specification may mean the claim will be denied.
So far as I can tell from an overall view, the visc designation only affects cranking with respect to ambient cold temps, and the additives only affect longevity. Like I said a few posts ago, Subie recommends 5W-30 in mine but she's sippin' on 20W-50 and there's absolutely nothing negative occurring at any time, so unless I see a bad effect as a direct result of using the wrong visc oil in something, I'm gonna declare that the recommendation doesn't actually matter.it’s more of a way to achieve fuel mileage increase than engine longevity!
