I did a 2" lift and now my rear wheel moved forward. How do I re-center the rear wheel? I got a subframe spacer don't know if that would work. Haven't been able to find a trailing arm for my Subaru year.
I thought the sub-frame spacer was necessary for the multi-link suspension to center the wheel - depends on which kit you've used I suppose?
I used the Ready Lift kit and it moved my wheel forward so the tires I wanted won't fit but I just installed the subframe spacer and it worked. Now I can get bigger tires put on. It raised the rear and moved the wheels back to center.
2016 2.5i Premium with 2" lift and rallitek rings
What subframe spacers did you install and where did you purchase them. I have the same problem and was looking at getting the spacer kit from rallitek. Glad to know it worked!!
