2015 Forester Ltd cvt
Looking for rear rotors for '15 Forester LTD and two diameters are coming up, 273 mm an 286 mm. Never heard of that before so what's the appropriate size?
2001 Forester
@Snap That's the diameter in mm. So just measure the ones on your vehicle now. The existing diameter might be stamped onto the existing rotor as well.
@bman400 Right, diameter is what I wrote. I hoped to get the rotors without pulling a wheel off.
2001 Forester
@Snap This link might help you: Brake Rotor Sizes
If it was me, I would buy the 273 mm ones. But if possible, can you buy both and return the other set? Possible you can measure just the radius and the 2x that for the diameter? 273/274 mm rotor vs 286 mm rotor diameter is nearly 1". you potentially could rig something up, take the rear wheels off a get a close enough measurement of the radius.
Searched Subaru parts: https://parts.ewingsubaruofplano.co...ited/BRAKE-DISK-REAR/49236072/26700SG000.html
273.8mm x 10mm
2019 Forester CVT
Try shopping by the VIN on a Subaru dealer web site. That will give the correct part # that you can deduce the diameter from.
