2015 XT Premium CVT
I had some work done and the mechanic threw away a few parts...
I've got the parts but can't figure out if anything goes in this hole where they overlap, they right piece wobbles a bit on it's own. Parts are located right below the front serpentine belt
The left part is a turbocharger stay #14421AA190, the right part is a water pump cover #21135AA000. Does something go in this hole? The spec sheet below isn't helpful.
If someone with a working XT can upload a photo I would be forever grateful.
Automotive fuel system Automotive tire Motor vehicle Automotive design Rim Organism Font Pattern Parallel Terrestrial plant
2015 XT Premium CVT
Discussion Starter · #2 ·
I've verified it's a bolt I'm missing.
Would someone be able to tell me the size depth?
Automotive fuel system Automotive tire Automotive lighting Motor vehicle Automotive design Automotive fuel system Automotive tire Automotive lighting Automotive design Motor vehicle
2015 XT Touring CVT
parts.subaru.com and order from the dealer. It looks like it might be a shoulder bolt (which will be harder to source) from your second picture.
2016 XT
Part # is 010110250 its the same as what goes in the other end, seen from below inbetween the cat and block according to the parts fiche.
