1 - 14 of 14 Posts
2015 Forester XT <Overland Style <Transformation in progress
So for those that are looking at doing a dual battery setup and on board air here is what I did in my 15xt.
* its not fully finished yet. Will make it more a bit more professional looking. *
Parts used:
  • Redarc Bcdc1225D
  • Redarc 40amp fuse kit
  • 100 Ah, AGM, Group 27, Battery
  • Viair medium duty onboard air system
  • Blue Sea Systems ST Blade ATO/ATC Fuse Block
I went with the Redarc Dc to dc charger because of its capabilities and that its solar ready. The forester has a "smart" alternator so you cant just do the solenoid style dual battery setup you need something that is capable of dealing with these types of alternators.
I went with the Viair Medium duty because I don't really need anything more heavy duty than what it offers. If im out on a trail ill deflate the tires a bit for better traction and reinflate them when i go hit the highway. With the Air tank i did have to buy swivel fittings to get it to fit into the spare tire compartment.
Basically I did my reasearch found what i wanted/ needed and bought everything i thought id need to install it.... I had no idea where I was going to install it. Only thing I knew was the battery was going in the trunk area of the cabin lol. I had a few rough ideas but liked the thought of putting it in the spare tire location the best due to ease of access for maintenance and Canadian winters.
the way i ended up installing it is with minimal modifications to the actual vehicle. The entire piece of wood comes out with everything attached to it. I used the threaded hole that holds your spare in place to hold the plywood in place.
Other than small mods to the foam, I did mount the switch and gauge for the air in the rear drivers side panel and a small indicator light into the dash that lets you know the status of the dual battery charger.
535619
535620
535621
So, the obvious question is - where do you keep your spare?
My spare is current in my shed lol.
I'm not going to be driving it much for a few months due to being away on work. But
For right now I'm carrying a tire repair kit. And I have the compressor. So if I get a flat I could possibly repair it. Unless something really stupid happens.
I'm also working with a buddy on making a rear bumper with a swing out spare tire carrier.
2019 Forester Limited
What led you to select the Redarc product? I wasn't aware of them, but see they are Australia-based and began US distribution in 2019.
To be honest I have no idea how I happened upon them. But they seem to be an awesome product so far!
Very nice set-up. Is there a voltage meter connected for the 2nd battery?
None yet. I'm looking at the Victron BMV-712 battery monitor. Bit pricey but the reviews are great. Plus it has Bluetooth.
I used the BMV-712 in a camper van. No problems. If relying on it for state-of-charge, make sure you recalibrate periodically. Nothing wrong with the unit; the nature of measurement has unavoidable drift.
Discussion Starter · #9 ·
Good to know. Thank you!
2001 Forester L Automatic
@SubiesAndBoobies Nice setup! Have you thought about running a line out of the spare area and somewhere behind the bumper so you don’t have to empty out the trunk should you need to us it?
Discussion Starter · #11 ·
@steve_k Yes. I'm collaborating with a buddy of mine to make a custom rear bumper with a swing out spare tire carrier and ill be making a hidden spot for it in the bumper.
Like your setup. I choose the Toyota repair kit including a very nice and accurate compressor/deflator. With my 215/60/16 tires I’m not afraid of draining the battery. Use the 12V outlet in the dash and trunk.
Verzonden vanaf mijn iPhone met Tapatalk
Very cool idea! Just another tid bit I’ll share. Ages ago I had friends making tube bumpers for their trucks and they would put fair fittings in the morning so they could be pressurized. Was helpful for topping up tires after off-roading.
2017 Forester
HAs anyone looked at fabbing a battery mount under the car where the second muffler would go? There looks like enough space for one and it would be well vented.;)
1 - 14 of 14 Posts
