I just did the front brakes on my 15 Forester Limited which had 60k on the original pads/rotors. I had no issues with the brakes but I figured I would do them before I had any problems. I saw no unusual wear on the old rotors or pads. I replaced the rotors and installed Hawk pads which I have had good luck with on my other cars. While doing the job, I took the caliper mount brackets off and pulled the caliper slide pins out and cleaned and lubed them. I noticed one of the pins has a ribbed bushing near the end and the other has none (same on both sides of car). When reinserting the ribbed pin I was met with some resistance but I was able to push it in. The brake pads seem to seat into the bracket nicely and I reattached the calipers with no issues. The brakes seemed to be dragging a bit and after a short drive, both front brakes were smoking! The calipers aren't frozen or anything as I was able to drive and stop ok, but they are definitely dragging. I installed Raybestos rotors 980360 and Hawk pads HB711F.661 D1539 HPS. I checked both and their respective websites say they are compatible with my Forester. I'm no pro but I've done quite a few brake jobs on many different cars over the years so I pretty confidant that I did it properly. I referenced a great you tube video that was helpful for the socket sizes needed. I'm thinking of replacing the caliper pins and bushings but I want to reach out here as there are a lot of experienced Subaru owners on here. I have another car available while I sort this out so I'm not dead in the water. Any suggestions? Thanks, Matt
